Need the spec, in "ft/lbs" for the standard plugs (Motorcraft AWSF-32C) without anti-seize. I have seen numbers, all over the place, but I am thinking somewhere around 10-11 ft/lb. Just need verification. Never used a torque, for plugs in the past, but maybe I am getting more picky in my old age. If I don't use one, I guess I could simply snug slightly past hand tight but that is not a very accurate way to do it. Non torque wrench tips would be appreciated just in case I decide to go that route. I know the later GMs and CVs had issues with plugs getting loose due to short thread lengths but I never heard that happening for this year. Just to satisfy my curiosity - do these engines have aluminum heads?
1993 Mercury Grand Marquis Spark Plug Torque Spec
Last edited by friskyfrankie; 10-06-2022, 10:47 PM.What I Own: 1993 Mercury Grand Marquis GS
What I Help Maintain: 1996 CV / 1988 CV / 1988 TempoTags: None
If you go with an upgraded plug that has nickel threads on it (platinum or iridium) then you shouldn't have to worry about it and they will last you longer. The black oxide ones seem to get stuck more often and could gall the threads. Just personal experience on the 4.6's I've worked on over the years. I've had the oxide ones get a bit hard to remove and was worried about damaging threads while the others simply needed a few turns back and forth to break them loose and spin out just fine with minimal effort.
I have always used 11ft/lbs. I don't like to guess on these heads since they have so few threads in them so I always use a torque wrench.
And yes, they have aluminum heads.These are highly engineered precision vehicles, the first step in diagnosing the problem is to strike the suspected offending part sharply and repeatedly with a blunt object, then re-test.
Originally posted by FordMan77 View PostIf you go with an upgraded plug that has nickel threads on it (platinum or iridium) then you shouldn't have to worry about it and they will last you longer. The black oxide ones seem to get stuck more often and could gall the threads. Just personal experience on the 4.6's I've worked on over the years. I've had the oxide ones get a bit hard to remove and was worried about damaging threads while the others simply needed a few turns back and forth to break them loose and spin out just fine with minimal effort.
And yes, they have aluminum heads.What I Own: 1993 Mercury Grand Marquis GS
12-17 ft-lbs IIRC, I'll pull my service manual when I get home and check. I always use a light dab of anti-seize on my plugs just for good measure.
I typically use whatever is the dead center of the range given.
Originally posted by sly View Post12-17 ft-lbs IIRC, I'll pull my service manual when I get home and check. I always use a light dab of anti-seize on my plugs just for good measure.
I typically use whatever is the dead center of the range given.What I Own: 1993 Mercury Grand Marquis GS
Originally posted by friskyfrankie View PostNeed the spec, in "ft/lbs" for the standard plugs (Motorcraft AWSF-32C) without anti-seize. I have seen numbers, all over the place, but I am thinking somewhere around 10-11 ft/lb. Just need verification. Never used a torque, for plugs in the past, but maybe I am getting more picky in my old age. If I don't use one, I guess I could simply snug slightly past hand tight but that is not a very accurate way to do it. Non torque wrench tips would be appreciated just in case I decide to go that route. I know the later GMs and CVs had issues with plugs getting loose due to short thread lengths but I never heard that happening for this year. Just to satisfy my curiosity - do these engines have aluminum heads?
If you have never used a torque wrench for plugs before I would not start now. After the horror stories about plugs in the 4.6 I got a torque wrench just for that, to be safe. Guess what, the old rule of thumb for tapered seat spark plugs (hand snug + 1/8th turn) just happens to be just right. And is a lot easier than trying to listen for a torque wrench click. Never used the torque wrench again. Lesson learned; if you got the feel for it, don't worry about it. People who've never done it before (myself included with the 4.6) get worried for nothing and get hung up on "perfection".
Originally posted by GM_Guy View PostIf you have never used a torque wrench for plugs before I would not start now. After the horror stories about plugs in the 4.6 I got a torque wrench just for that, to be safe. Guess what, the old rule of thumb for tapered seat spark plugs (hand snug + 1/8th turn) just happens to be just right. And is a lot easier than trying to listen for a torque wrench click. Never used the torque wrench again. Lesson learned; if you got the feel for it, don't worry about it. People who've never done it before (myself included with the 4.6) get worried for nothing and get hung up on "perfection".What I Own: 1993 Mercury Grand Marquis GS
NPI engine is 20Nm 15lb-ft (2000)
PI engine is 15Nm 11lb-ft (2001-2003)
Edit:
Looks like 93/94 shows even less. 9-12 Nm 6.6-8.8 lb-ft
Edit:
Looks like 93/94 shows even less. 9-12 Nm 2.2-8.8 lb-ftWhat I Own: 1993 Mercury Grand Marquis GS
I have the official Ford CD/DVD manuals for 93/94 cars and 2000-2003 all passenger vehicles. So those are the official numbers from Ford for the years specified.
Originally posted by sly View PostI have the official Ford CD/DVD manuals for 93/94 cars and 2000-2003 all passenger vehicles. So those are the official numbers from Ford for the years specified.What I Own: 1993 Mercury Grand Marquis GS
should be 6.6 to 8.8 lb-ft. Just saw my typo. dunno how the hell I put 2.2. Bah.
Yeah... kinda need an inch pound wrench for that.
I think I still used 12-15 lb-ft on my 93 with the original engine. *shrugs*
