Long story short, I got the wrong service manual for my TC, (97), so I would like to know where I can find the troque specs for the front end suspension (upper/lower control arms, tie rod ends, stabilizer links, ball joint studs, shocks). Any info would be greatly appreciated
Front end suspension torque specs
This is a sticky topic.
Are you looking for specs for a 97 Tc? or the 89? You got the 97 book by mistake instead of the 89 or?03 Marauder DBP, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
08 TC Signature Limited, HID's Mods>235/55-17 Z rated Cooper Zeon RS3-A, Addco 1" rear Sway, Posi, Compustar Remote Start, floor liners, trunk organizer, Two part Sun Visors, B&M Trans drain Plug, Winter=05 Mustang GT rims, Nokian Hakkapeliitta R-2 235/55-17
08 Escape Limited V6 Auto, Beamtech LED headlight bulbs,
No, I ordered a service manual for the 1997 TC, but I got a 97 CONTINENTAL, (the order was mixed up), so I need the data for a 1997 in the mean time till I order the right manual (well hopefully they get it right next time)"To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
This is all off the top of my head:
ball joint nuts - 100-120 ft-lbs
control arm nuts at the bushings - 100-120
alignment bolts (hold the upper control arm rod to the frame) - 80 but I always use breaker bar tight - around 120 or so, but then my 88 has all the rough patch for the bolts to tack to kinda flattened.
all the castle nuts so far that I've done were specced to 100
sway bar links: locknuts (pinch or nylock) and should be obvious as the bushings squish down. Once they are compressed to the bar or control arm give another turn or so and you're done. They won't really torque down until you run out of threads or squish the hell out of the bushings.
good n tight, approximately 1/2 turn before it breaks.
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
wow... was I right with all those numbers? That's just what I guessed at because I always just use breaker bars to tighten that stuff (except ball joints/tie rod ends - I get the torque stick for that).
Originally posted by sly View Postwow... was I right with all those numbers? That's just what I guessed at because I always just use breaker bars to tighten that stuff (except ball joints/tie rod ends - I get the torque stick for that).
'80 Town Coupé
