Battery Idiot Light????
    1999 MGM with the digital dash. When I'm going down the road, high and low speed, somtimes the battery light will come on the dash. Usually, if I rev the engine a little more it will go off. Alternator appears to test good. It's driving me crazy. Any thoughts?
    Check your connections at the battery and fuse box. I had a problem where the alternator was not in good contact with the batter and the car was only running off of battery till I cleaned everything and tightened up the connections.
