Welcome to the test copy of the new GMN. This is purely for testing. Nothing posted here will be saved, so please don't post anything important here. The data is from a copy of GMN from right around Thanksgiving 2022, so there are some gaps but there is enough here to work with. Please let us know what works and what don't so we can try and debug this before the final move.
Thanks!
That should make it easy. Looks like I can just tie the little wire at the starter solenoid on the 92 into the same wire on the 91 harness to backfeed the TFI module for start ignition power. Theres possibly some cleaner way to do it, but I'm looking to make this as minimally invasive as I possibly can .
