Digital Gear Indicator?
  • sly
    replied
    Yeah... I was contemplating that with a stock 88 MGM dash. Definitely not worth the squeeze for me.
    Leave a comment:
  • Swayze
    replied
    I looked at one of those, but after finding out all the stuff I would have to change/modify for that, I didn't feel like it. It needs a true gear position sensor and IIRC, the boxes don't have one. It's just a neutral safety switch that allows start in P and N and then a reverse light switch. You'd have to fabricate a position sensor for the column or the trans. I think Dakota sells a bolt on one but you would have to fab a bracket for that one that would probably have to be mounted by using the trans pad bolts which would require some finagling to get around the pan lip. And that's just what I can remember off the top of my head. There may be newer/better position sensors to use with the display that would simplify life.
    Remember im swapping 05 under 84 and using 05 gauges. I can probably get the needle style to function but just looking at these. Would give a little more clearance if the box housing the needle could be removed. It will ultimately be an is the juice worth the squeeze scenario
    Leave a comment:
  • sly
    replied
    Leave a comment:
  • friskyfrankie
    replied
    Cool! So about $300. Didn't get a chance to peruse the installation video so would need to see if it is worth the effort. Thanks for the photos/links!
    Leave a comment:
  • Swayze
    replied
    Originally posted by friskyfrankie View Post
    Never even seen one. Got a photo/link to a product?
    Leave a comment:
  • FordMan77
    replied
    I know Autometer has one.
    Here is a link to Dakota Digital that also has them--> https://www.dakotadigital.com/index....cat/cat401.htm
    Leave a comment:
  • friskyfrankie
    replied
    Leave a comment:
  • Swayze
    started a topic Digital Gear Indicator?
    Has anyone ever added an aftermarket digital gear indicator “PRND12” etc.?
