Replaced the Multi Function switch today and had an interesting time getting the lock cylinder out. Had it in "Run" and probed the hole to push the "ball" up so I could pull it out. Finally got it to work but after reinstalling it I noticed the warning charm goes off when I open the car door and before I put the key in the cylinder. Didn't do that before I removed and reinstalled so is this normal or does it just supposed to chime with the door open and key in?
1993 GM Ignition Cylinder Question
Originally posted by massacre View PostSometimes the chime thingy gets out of place, or the wire gets pinched. Happened to me on my 93 once.What I Own: 1993 Mercury Grand Marquis GS
yeah its just a little plastic thing, easy to knock it out of position or to have the finger get bent.
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Makes sense as something has to trigger it. Guess the question still remains: Is it normal for the chime to work when the driver's door is opened before inserting the key in the ignition or does the key have to be inserted as well?What I Own: 1993 Mercury Grand Marquis GS
Even if you don't ever disturb the lock cylinder, that can get out of alignment. Mine is loose and I have to jiggle the key wings to get things back centered since they are no longer firmly attached.
no it shouldn't chime with no key in the ignition.
Vic
~ 1998 Mercury Grand Marquis LS - new DD
~ 1991 Mercury Grand Marquis LS "The Scab" - plenty of rot, backup/summer cruiser
~ 1997 GMC Yukon SLT - wannabe winter DD - many issues, returning sometime in the 2020s
~ 1991 Mercury Grand Marquis GS "The Ice Car" - Rotting Retired Winter DD
~ 1989 Mercury Grand Marquis GS - Rotting Retired DD
Gone but not forgotten:
~ 1988 Country Squire ~ 1987 Ford Crown Vic
Excellent as that is what I thought. Thanks guys for confirming what I need to know and for the great photo of the cylinder. As long as I don't have any negative issues from it I'll call it righteous repair and done!What I Own: 1993 Mercury Grand Marquis GS
Originally posted by GM_Guy View PostOr just unplug the wire for the chime and never be bothered by it again.What I Own: 1993 Mercury Grand Marquis GS
