interchangable 5.0 Lopo and 5.0 HO distributors?
    Hi,
    Are the distributors for a 5.0 lopo and a 5.0 HO Mustang interchangeable?
    Thank you,
    Mike
    90 Colony Park LS with GT 40 heads and intake. HO cam, 65 MM TB, 67 MM EGR spacer. Has a 75 MM Pro Flow mass air sensor. Borla XS mufflers. 3L55. Shift kit, 2000 stall Tq convertor...Bilstein shocks, front and rear sway bars.
    90 Colony Park LS 64,000 miles all original. 3L55 tow package....front and rear sway bars.
    91 Grand Marquis GS....HO motor..Bilstein shocks poly bushings and police swaybars. This one handles the best.
    70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All original
    Yes
    03 Marauder DBP, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
    08 TC Signature Limited, HID's Mods>235/55-17 Z rated Cooper Zeon RS3-A, Addco 1" rear Sway, Posi, Compustar Remote Start, floor liners, trunk organizer, Two part Sun Visors, B&M Trans drain Plug, Winter=05 Mustang GT rims, Nokian Hakkapeliitta R-2 235/55-17
    08 Escape Limited V6 Auto, Beamtech LED headlight bulbs,
      Thank you Jaywish,
      I bought a rebuilt one as a spare a few months ago and had hoped it was correct.
        yep, same stuff
          Thank you too Scott,
          Scot, I believe you sent me a message a long time ago in reference to 11 inch backing plates. I apologize for not replying. I've had too much crap going on with the car and my work.
          Do you still have them available? If so can I buy them?
          Thank you for all of your help thru the years.
          Mike
            Mike
            yes i still have a set.
            i'll take 40 bucks plus shipping for the pair
            send me a pm and we will fig out shipping
              Hi,
              Thank you,
              Mike
              Are they both roller engines?
                All '86 and up 5.0 are roller. A good rule of thumb is that if it's SEFI, it's got a roller cam. Of coarse there's one exception: 1985 HO is carb ... and was the first roller cam
                88 Country Squire
                86 Colony Park, non-op'd
                89 Mark VII LSC, non-op'd
                  Good info. Nice wagon!
