site will not load properly on any of my three browsers.
trying to add picture
Originally posted by ootdegaMy life is a long series of "nevermind" and "I guess not."Originally posted by DerekTheGreatBut, that's just coming from me, this site's biggest pessimist. Best of luck
why does your TV cable have a weird spring between the end of the cable and the plastic stem?
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Yeah... that spring shouldn't be there. If the plastic won't stay out to support the cable, there are mods you ca do to fix that. The trick I used was to pull it out to where it needed to be, "latch it in place" and then put a split rubber hose over the plastic and clamped it in place with a tiny worm clamp. That held it in place perfectly well for several years before I sold the car.
That should be for the transmission. However... all of this said... IF it's working and not shifting like a lazy sloth, just leave it be. If it ain't broke, don't break it.
