Ford Head Flows
This is a sticky topic.
  • 1990LTD
    replied
    Cool. Thanks Now, what to do with them when I yank them off of that engine?
    Leave a comment:
  • packman
    replied
    Leave a comment:
  • Mercracer
    replied
    How does one identify stock cylinder heads? I don't see any numbers stamped on the Ford heads. Though, I could probably scrape off the rust and take a good look. Engine is a '96 351W. I'm going to go out on a limb and assume that I got E7 heads, as I can't see Ford putting anything more than that on a F-250.
    Ford used E7TE heads on mid 90s 351Ws. You will find the numbers cast on the bottom side of the intake ports. With the intake off and a mirror you can see them without removing the heads.
    Leave a comment:
  • packman
    replied
    Leave a comment:
  • Mercracer
    started a topic Ford Head Flows
    Ford Head Flows
    http://www.allfordmustangs.com/Detailed/630.shtml
