Ford Engine Dimensions
This is a sticky topic.
wow... the mod motors are pigs on weight. Never woulda guessed that.
The DOHC mod motors are NOT the same size or weight as the SOHC. They are much wider and heavier. Sure, they're aluminum head, but still iron block and a shitload of extra junk in the motor. 2-4 cams and the accompanying stuff to make them work? Yeah, lots of weight. That and the blocks are much meatier than the old SBF blocks. Hence, they don't blow up quite the same...
I have a 351C in a ex stadium race truck a ranger long bed on a 67ish bronco frame. Lots of parts for C motors from previous builds have often thought about a C swap. My last C motor pulled 500 hp @ 6000 RPM and 500FT/ LBS @ 4200 rpm for a friends Pantera. That was stock stroke and .030 over bore.Scars are tatoos of the fearless
