Transmission oil cooler
    Any tips or ideas on an external transmission oil cooler
    I have an auxiliary cooler on my '95 T-bird, my '01 Mercury GM, my '77 F-150, and my '07 FX4 has a large factory one with it's heavy towing package. The one on my '77 has been on it since the late 1980s, it is behind the radiator but ahead of the fan. The Mercury and T-bird got their's maybe 5-6 years ago. When I add one, I add it in the return line to the transmission. I also use at least 2, often 3, and maybe sometimes 4 ... screw type hose clamps.
    5 is OK too.
    Reminds me, I should order some new trans lube fluid rated hose for the truck, getting some age on it.
    No ... I'm not arguing with you ... I'm just explaining why I'm right ...
    Now go ... and whatever you do ... have a safe trip!
      I have a Hayden 699 that I will probably get around to installing next year. I found cooler mounting brackets from certain GMT400 trucks ('88-'98/'99) with the Hayden 699 look like it will be really close to a perfect fit.
      Vic
      ~ 1998 Mercury Grand Marquis LS - new DD
      ~ 1991 Mercury Grand Marquis LS "The Scab" - plenty of rot, backup/summer cruiser
      ~ 1997 GMC Yukon SLT - wannabe winter DD - many issues, returning sometime in the 2020s
      ~ 1991 Mercury Grand Marquis GS "The Ice Car" - Rotting Retired Winter DD
      ~ 1989 Mercury Grand Marquis GS - Rotting Retired DD
      Gone but not forgotten:
      ~ 1988 Country Squire ~ 1987 Ford Crown Vic
        This is a page from B&M catalog
          On my '01 Mercury GM, the '95 T-bird is simular.
            Here's what was on my 93 and the current one I put on. Hayden 678 cooler. It's overkill for sure, but this car was my tow rig at the time, so I went with "it ain't done until it's overdone." The old cooler was put on by the trans shop that rebuilt the trans at 106K miles. I now have almost 260K miles on it and just needed to replace the torque converter once around 200K.
            Cake has an upgraded trans cooler (a real one now) and trans fluid temp gauge.
            old cooler:
            [ATTACH=CONFIG]47366[/ATTACH]
            new one in:
            [ATTACH=CONFIG]47365[/ATTACH]
            Temp sensor:
            [ATTACH=CONFIG]47367[/ATTACH]
            Gauge:
            [ATTACH=CONFIG]47368[/ATTACH]
              I used a Flex-a-lite transmission cooler with the -6AN fittings. I'll get the part# for it when I get home as I can't find it on their site.
              http://www.grandmarq.net/vb/showthre...oria-LX/page18
                I have used the Hayden cooler. They work good. My favorite is a Crown Vic. Police package cooler. Complete with the mounting brackets and fittings. Fairly cheap if you get one from a Pick a part type wrecking yard .
                  I also run an auxiliary transmission cooler in my 85. It was an inexpensive addition, easy to install, and serves for some peace of mind.
                  1985 2-Door: CFI, K&N Filter, Edelbrock Performer 289 Intake, E7 Heads, BBK Shorty Headers, Summit H-pipe, Hooker Max Flow Mufflers, E-Fan, 3G Alternator, ASP Underdrive Crank Pulley, Bilstein Rear Shocks, Rear Lowering Springs, KYB Front Shocks, Front Lowering Springs, FTI 2400 Stall Converter, PA Performance Valve Body, Ford Racing 4.10 Gear, Eaton LSD Differential - I own quite possibly the fastest CFI powered box to the 1/8th mile: 9.95@68.89mph
                  1991 4-Door (Dad's Car): Pro-M EFI, 306ci, Ford Racing Aluminum Heads, COMP XE264HR cam, Cobra 1.7 Rockers, Edelbrock Performer RPM 2 Intake, 30lb. Injectors, Custom 65mm TB/EGR Spacer, Pro-M 75mm MAF, BBK Ceramic Shorties, Custom Summit H-pipe, Walker Mufflers, ASP Crank Pulley, Jegs Built AOD, 3000 Stall Converter, Ford Racing 4.10 Gears
                    I have the B&M hi tek with a fan, the bigger model. I have a high stall converter and 4.10 gears so i want to make sure atf stays cool. AN-6 stainless lines and fittings. Also have a deep pan and temp gauge.
                    I had it mounted in the Panther and it was fairly easy with plenty of room.
                    I am actually trying to fit it on the zephyr now and it is much more challenging. Very little room because of the older style bumper and nowhere to hide it.
                      I really appreciate all the help I also forgot to mention that I have a 88 tc stock... gonna play with the stock block before I eventually swap engine and trans
                        I did the same cooler setup (no gauge) on the 88 MGM I used to have.
