Alternator wiring diagrams: 1G, 2G, and 3G
This is a sticky topic.
Originally posted by ootdegaMy life is a long series of "nevermind" and "I guess not."Originally posted by DerekTheGreatBut, that's just coming from me, this site's biggest pessimist. Best of luck
Good stuff Michael. I should do a 3G swap on my car...**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
**2006 MGM,"Ultimate": 4.6/ 2.73/ Dark Tint, Magnaflows, 19s, 98K Daily Driver
**2012 Harley Davidson Wide Glide (FXDWG):103/ Cobra Speedsters/ Cosmetics, 7K Poseur HD Rider
**2014 Ram 1500 QCSB Express: 4WD Hemi/ 8spd TF/ 3L92/ Exhaust/ Cosmetics, 42K Truck Duties
I actually saved the 3G one on my computer from another thread just in case it was never to be seen of again on the interwebz.~David~
good stuff indeed!Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Thanks!!
Oh btw, if I go to the parts store and ask for an alternator-- will it necessarily be 3g, good for 165 amps, nowadays? Or is that a particular request?
I don't often make it to junkyards... and if the price difference is not so great, would prefer new to 10 years old and 150k miles with some rain into the open hood.
If you ask for an alternator for your car you will be given a 2G probably 65a (small case) or 100a (big case)sigpic
parts store will usually charge somewhere near $200 (around $180 +/-20). Junk yards generally have them around $60-90. Some yards that I've seen selling on ebay have had them as low as $35, but after shipping it's closer to $60.
Guess I should have replied on here instead of in a PM.
- The Box Panther 100A alternator was a large-case 1G. Complicated and pointless to retrofit that to a 2G car when swapping a small-case 3G is like falling off a log.
- 3.8L Mustang alternators (small case 3G, 95A) can be had starting at $100ish at Autozone ($80ish if you're Scott), or starting around $25 used (check car-part.com for listings in your area). I used 1995 as a reference model year in my searches.
- I recall Scott telling me he gets large-case 3Gs (130A) from Tauruses, but don't remember the details (year, engine).Last edited by 1987cp; 08-29-2010, 11:23 PM.2012 Mazda5 Touring | Finally working on the LTD again!
For the 2g alternator, the wide connector with the two 12 or 10 gauge black wires-- both are hots if I'm reading that right?
And-- when I install my 3g alternator, do I want to use them, or do I want to run a fatter cable straight to the battery?
Any harm in maybe even doing both --taking the original charging cable and fitting o-ring terminals to attach them to the 3g, AND running a large gauge cable to the battery-- after all, the more total wire gauge the less loss right? But I have a memory of running two A/C hots together that were out of phase and ending up with 220V at a 110V outlet,scared the crap out of me when it started sparking and burning up-- don't want to do that if that could happen.
Yes the two fat cables are hot. I would just run a nice 4 gauge wire from the charge stud to the battery or starter solenoid. Eliminate the old 2g alternator wiring and fusible link BS.~David~
do not use the 2G wires. They are not large enough for a 3G. You will burn them up if you use them. You can also disconnect them from the wire-mess at the starter solenoid.
I used one of the charge cables from here and just ran it across the top. The charge stud extender would be a wise purchase too (and would have given me the slack needed to not use another 6" battery cable extension). They also had assembled versions when I ordered. Apparently that's changed. You can also use bolt down battery/starter cables (4 gauge wire or fatter) and just get one long enough to make it to the fender where the charge cable megafuse should be (175A on mine) and then another short cable to the starter solenoid.
Interesting link, though an unnecessary expense IMO. You can reuse the 2G regulator plug (it's the same) and eliminate everything else. Can attach the stator wire around to its new home with a spade terminal or see if AZ has the proper plug; other than that, it's basically just a starter cable for charging and a ring terminal to loop the yellow wire back around to the charging stud.
+1 on not reusing the ancient stock charging wires. You can fish them out of the headlight harness if you ever have the ambition to do so.Last edited by 1987cp; 05-02-2011, 10:50 AM.2012 Mazda5 Touring | Finally working on the LTD again!
