Under Hood Insulation
    Does anyone make MOULDED under hood insulation? I see plenty of flat ones, but none like OEM.
    -Phil
    Not that I know of.
      A guy in PA makes some really good ones (flat) but thick and cut very well. You can order it through EBAY or directly from the manufacturer. If you are interested, let us know and I'll try to dig out the info.
        I believe I stumbled upon his stuff. I was a little skeptical of the quality based on the picture, but he said it’s an outdated one. You’ve seen his product before and it looks good? If so I’ll probably order from him
        https://www.ebay.com/itm/32466827561...Bk9SR6jqtPeTYQ
        -Phil
          That is the EBAY contact I was referring to. His communications are good and the product (as of a few years ago) was quality. May take a little while to get as they are sometimes cut to order but they do have the specs for many cars so there might just be one already made. I had a few done and one had to be custom made from some specs and a really beat up one I sent and the results were dead on. As long as he is still doing the same quality work, you'll be happy.
            That's great to know- I ordered it! Thanks
            -Phil
              Cool - let us know how it turns out!
