1997 Volvo 850, new old friend
    Here it is, the winter beater I sorely needed since my MGM didn't turn out as "good condition and fully functioning" as it was advertised. With a limited budget my choices were tight, since I wanted an autobox and cruise control. It ended up being a Volvo like this or maybe a Neon or Sebring. Quite glad I went with this magnificent piece of swedish agricultural equipment. Even 20 years later, an 850 is still a better car than a Neon...
    I paid 750€ straight cash at an outlet dealer. Came with ok condition summer and studded winter tires. And an unopened timing set in the back.
ID:	1305073 Click image for larger version
ID:	1305074 Click image for larger version
    It ain't perfect, price tells you that of course, but it ain't bad either. Mostly the paint, terribly faded, the plastic bumpers and mirror covers are a bit better off. Interior is in excellent shape, except for a few rattles (pic is missing the passenger knee panel) Overall feels very solid and runs very smooth.
ID:	1305076 Here you can see the difference, probably never spent a day out of the sun, or got a vax.
    Some flaws:
    - Odo and tripmeter stopped around a year ago @342000 km, digital trip works and showed 2066kms when I bought it. I'll have to write up readings until I decide to fix it
    - Blower blows only at max, needs a new blower motor resistor module, already ordered the new part
    - Gas pedal is quite stiff, throttle cable was DIY-fixed at some point
    - Rear hatch doesn't stay up, needs new struts
    - Hinge detents have worn away on 2 doors
    - Timing belt is due at some point, can't be exactly sure of it's mileage due to odo stopping
    Other curiosities / features:
    - 2.4l 10v Inline-5, B5252FS, second smallest engine
    - Very comfy grey cloth interior with wood effect (that's definitely better quality than in my MGM)
    - Manual heater, no AC
    - 4 door power windows
    - Heated seats in the front and the back
    - Cruise control
    - Electric mirrors
    - Manual seats
    - Remote central locking and a Volvo OEM auxiliary alarm system
    - Original CD/AM/FM radio with a keycard lock (there's seriously a keycard with a chip that needs to be inserted with an orange tray, to use the radio)
    Although to slightly lesser effect, it has that "safe and sound", familiar feel, like an old friend that can be trusted. Just like my first car, a 2002 Volvo V40 T4. I would've probably kept that car forever, if it weren't totalled by a bishop that failed to yield.
    Only thing that breaks the effect is the slightly ricey backbox that makes the thing sound like it's got twice the HP, which I don't like.
    Makes me feel nostalgic and sad about my first car, but now I definitely understand why there's so many fanatic Volvo owners.
    Best enjoyed when it's dark, raining and you're driving in the city outskirts with CCR or Kansas playing from the radio. It's gonna be fine, I'm safe and sound, everything is gonna be fine eventually... It's what I wanted from my MGM, but it seems I'll have to carb swap and DD it for the next 15 years to feel the same at all, also it should've been more base model.
    For a winter beater, it looks like you got quite a stout car.
    As far as the paint goes, it could pass for a southeastern car over here. Plenty of faded out cars having been left in the sun too long.
    My Cars:
      Nice ride. You can bring a temporary shine back to the car if you put in the effort. I like it.
        I approve.
        A coworker had a similar wagon, a bit older, but also red.
        We were competing for the last eleven years to see whose would last the longest - my ‘88 or his Volvo. I won this past summer.
          Nice. I love my V70. I've actually been looking to swap it with 850 wagon but they are getting harder and harder to find around these parts especially optioned how I want. T5 with a stick.
            Got the blower resistor today, it's just behind the glove box. 9 torx screws and the glove box door limiting straps.
            It's this small module, screws to the heater box, has a 4pin plug.
            What actually failed is the thermal fuse that looks like an inline resistor. I checked it by jumping it with wire.
            To change it would require tracking down that fuse, it would need high-temp solder so I just bought the whole part new for 12€.
              Might want to try and get some oil on the blower motor bearings if you can. Those fuses usually pop when the motor is overloaded, either from sticky bearings or just being packed with junk that keeps it from spinning properly.
                These resistors going bad are supposedly somewhat common in these, can certainly be caused by a worn blower motor. But apparently can break with time aswell, some say that the thermal fuses don't age well.
                If this one blows the fuse soon, then I'll take a look at the blower motor. Don't have the time or willingness to put money into this. Though I should find out if the blower motor is serviceable.
                  Installed new tailgate struts, 50€ for the pair, a bit pricy IMO, but considerably less annoying now, so I guess that's a win.
                  Also bought an FM-transmitter to avoid buying a new headunit and keeping cost low. Actually quite nifty and even a dumbass could get it working. Also bluetooth for calls and less wires to get tangled, also has 2 usb ports for charging (2.4A).
                  Trying to find new door limit/detent mechanisms, they seem to be better available new there in the States for some reason. I don't know if I dare to go ask the price at the dealer.
                    Apparently this thing does have AC, there's a snowflake -rocker switch on the controls. Only on the automatic climate control models it says "AC on/off"
                    Cool. Literally. Not that I'll need it during the next 5-6 months...
                      Really bad misfire when cold, barely any throttle response. No CEL, haven't checked codes though.
                      Decided to check the basics, I don't know much of this cars maintenance apart from the big things.
                      Changed plugs, rotor and cap. Plugs were just old, rotor and cap had some crud on them, nothing too bad.
                      Distributor is in a really crappy spot in these, sideways in between the cyl head and airbox. I removed the airbox lid to ease things, the intake hose just crumpled and broke in half...
                      Removed the rest of it and took a look down in there...
                      Yum!
                      So I'll get some generic silicon hose piece to replace the original one, since the original can only be bought with the throttle body collar thing for 60-70€.
                      Before that I'll remove and clean the throttle body and collar.
                      The damn plastic cover for the spark plug valley is attached with 6(!) torx 30 bolts, the four left were absurdly tight. The last two were snapped of in the cylinder head by a previous owner...
                      Also the damn cap is installed with 3 8mm bolts, one of which is below the distributor and reaally hard to get to, even with the airbox removed.
                      Distributor rotor is in with 3 allen bolts.
                        Went hunting for a new throttle body gasket (I haven't taken off the TB yet).
                        Not available from any general parts stores... Went to a Volvo dealer, could've ordered the small paper gasket for 9€. Estimated arrival on 2nd week of Jan. Yeah no thanks.
                        Also the intake pipe was available for order, for 60€ (for a short piece of plastic pipe, no bungs or anything) No thanks to that either...
                        So I picked up a can of throttle body cleaner and I'll use gasket maker instead. I'll figure out a fitting silicon pipe or just duct tape the original back together.
                        Funny thing is those damn tb gaskets are readily available on fcpeuro and ipdusa, and for like $1.43.
                        Also I found the door detent mechanisms on an US-site.
                        For some damn reason obscure parts on non-obscure Volvos are better available there over the great pond rather than here, the neigbouring country of Sweden.
                          Worldwide logistics... go figure.
                            Why am I not surprised?
                              Sometimes stupid things are just way too expensive. Needed new hoses to connect from turbo to crossover pipe and then from the pipe to the intake on my diesel. Each hose is about 3" long. It would have been over $100 for those two short pieces of rubber hose from BMW. I bought generic bits of silicon hose intended for ricer tuner crap on ebay with nice new clamps for under $20.
