this is my Aeromotive fuel pump and regulator, this should keep that 351 well fed
Fuel pump
Fuel pump
this is my Aeromotive fuel pump and regulator, this should keep that 351 well fedhttp://secondhandracing.com/Home.aspx
http://www.grandmarq.net/vb/showthread.php?t=5634Tags: None
total cost is about $200 the regulator and guage are new $100 for both and the pump $160 new is used so about $100http://secondhandracing.com/Home.aspx
Ideal for daily drivers, street rods, boats, and bracket cars, these Street Rod fuel pumps will deliver the durability and reliability you expect without breaking the bank. Just look at some of these features: 900 lbs. per hour of fuel flow at 13.5 V, 18 to 20 psi fuel pressure, a highly durable pumping mechanism guaranteed to never wear out, 3/8 in. ports, alcohol compatibility, and a low amperage draw. How can you go wrong?http://secondhandracing.com/Home.aspx
