HeLp 4.6 no start
    HeLp 4.6 no start
    1994 mercury cougar 4.6 ran last night fine, this morning cranks but no start, fuel pump primes fuel at shcrader, will both coil packs fail at the same time? or is this a crankshaft sensor problem?
    looking for things I can check this is my bros DD.
    Moved to correct forum...
    2000 Grand Marquis LS
    Mercury Owners Group member
      Check the crank sensor connections. Very unlikely that both packs fried at once. The EDIS module is also a possible but the sensor plugs seem to be more of an issue.
