I can't get to the bolts underneath the car!! :cuss: I have tried jacking the car, and jacking up the system at all different heights and I just can't get a wrench up to those bolts. I even used a special adapter that lets me go sideways and whatnot with the socket. this is the passengers side im having trouble with, i haven't attempted the drivers. Can the heads be removed without taking off the manifolds?
how do you get exhaust manifolds off
I used an 11/16 deep socket on my 3/8 drive ratchet with 18-24" of extensions. Hit them with some PB Blaster or WD-40 and let them soak for five or ten minutes before you try to break them loose.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Originally posted by Blaze86Viconly PB Blaster is good enough, all else is worthless for this job IMO)
I actually used Aerokroil. If that stuff was any stronger, it'd loosen the welds themselves!2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Originally posted by mrltdI got fed up with mine and took a sawzall to it
You guys don't understand, I CANNOT get to my bolts, there IS NO WAY. I'll have to take a picture. I'm gonna :hacksaw: the shit off.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Unless your car is dramaticly different than any other, the flange bolts should actually be pretty simple to get at. long extension and an 11/16 (or 16mm, whatever) socket with a swivel and you can get them. I used a flexi-socket last time, one of the types with the flex part built in. It was a medium well, not a -deep well but they came out decently easy. The ones on my car wouldn't let go and I ended up taking a die grinder to them, but the CV I pulled them on this weekend actually broke loose. If you have a torch handy, get those suckers good and hot and they'll come right apart. Get them glowing, then jam the extension+socket on it and crank away.
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
if you arent saving the pipes, the sawzall works well :chainsaw:
He also has a 4 cat h pipe. I took one look at the one on my vic and said F it and got the sawzall!
Originally posted by 89LincolnTWNcarYou guys don't understand, I CANNOT get to my bolts, there IS NO WAY.
I am still confused as to which bolts you are talking about. the bolts that hold the pipe to the manifold? or the bolts that hold the manifold to the head? I either case, both are not terribly difficult to get off.
if it is the bolts that hold the pipe to the manifold and you dont plan on using the stock pipes anymore, just cut the pipe 3"-4" behind the manifold and be done with it.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
I found that you can get most of the manifold to head bolts out with a flexi socket and long extension right through the wheel wells. Saves some scrapes on your arms.
I was able to easily access all the manifold-to-head bolts on mine... but I'm running Mustang stock "headers" and I have a warm-air intake that only required loosening one screw to remove.
I also didn't need any swivel anything for the manifold-to-pipe bolts... but my entire exhaust has been replaced.
Thinking about it, after this, the driveshaft and rear axle will be the only stock parts on the drivetrain... and even those will be replaced before long.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
