Well, when I was driving the car earlier the trans started downshifting very HARD. I dont know wtf was going on with it, but it was bad. I felt every gear. I got to the nearest gas station and checked the fluid, less than a half qt. low. okay, I filled it up. Shifts fine. I havent found any leaks, no drips on my parking space. Slow leak maybe. Why was it shifting wierd? Anyone? Think I should risk it and change the fluid, since I dont know when it was changed last? It's still red and clean looking, but I dont know. Bad things happen if it hasnt been changed lately.
{Transmission}Trans problems
change the fluid and filter, just dont dump the fluid out of the convertor......the aod holds 12 qts, doing a service usually takes 4-6 qts.......if you are worried, add a bottle of lube gaurd or lucas tranny treatment
scott
If it's shifting fine after you added the fluid, then that would be your best guess as to why it was shifting hard, unless I'm missing something.
-Jeff-My CarDomain Page
2002 P74
Arizona Beige
20% Tints All Around
Tinted Tailights
Clear Corners
Sound System
Leather Interior
