Anyone know max numbers (lift duration etc) you can run with iron heads. Can be any year iron 351w heads.
351w Cam
the max you can run is dependent on the size of the valves and piston style, and your valve springshttp://secondhandracing.com/Home.aspx
"It Depends". the almost-always correct answer in case of vague questions.
and yeah, what he said is why.
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Also, I'd upgrade the heads before the cam on a 351W crown vic. The cam isn't THAT bad. it has around the same lift as an HO cam, and more duration.
CS674
Cam Type : Hydraulic
Exhaust Duration : 195 Deg.
Exhaust Lift (Inches) : .260"
Exhaust Lift (mm) : 6.604 mm
Intake Duration : 195 Deg.
Intake Lift (Inches) : .260"
Intake Lift (mm) : 6.604 mm
Lobe Centerline (Exhaust) : 112 Deg.
Lobe Centerline (Intake) : 103 Deg.
Lope Separation : 108 Deg.
Overlap : 55 Deg.
CS764
Exhaust Duration : 221 Deg.
Exhaust Lift (Inches) : .283"
Exhaust Lift (mm) : 7.188 mm
Intake Duration : 206 Deg.
Intake Lift (Inches) : .278"
Intake Lift (mm) : 7.061 mm
Lobe Centerline (Exhaust) : 114 Deg.
Lobe Centerline (Intake) : 116 Deg.
Lope Separation : 115 Deg.
Overlap : 46 Deg.
these are the two cams listed for Crown Victoria 351W applications. Just by sound and feel I'm inclined to believe my 85 came with the 764 but it's unclear when the switchover date was or if there even was one. Like I said, on paper, not that bad. I'd go for new heads a long time before I switched it out for a cheapie one-size-fits-all camshaft.Last edited by johnunit; 03-22-2011, 11:59 AM.
Overlap : 46 Deg.
Overlap : 55 Deg.
CS764
Overlap : 46 Deg.
these are the two cams listed for Crown Victoria 351W applications. Just by sound and feel I'm inclined to believe my 85 came with the 764 but it's unclear when the switchover date was or if there even was one. Like I said, on paper, not that bad. I'd go for new heads a long time before I switched it out for a cheapie one-size-fits-all camshaft.Town Coupe [X]
Mark VI [ ]
Grand Marquis Coupe [ ]
Crown Victoria Coupe [ ]
