This is for those who have CFI/EFI box Panthers with the in-tank fuel pumps. I started by purchasing a stock pump (Spectra) from RockAuto. As we know, the stock pumps are physically larger than the aftermarket Mustang pumps (mine is a Holley 190lph). In order to get them to fit correctly inside the rubber boot, you have to fill in the empty space with something. I used a NAPA (part#8104) radiator hose for some '80s Chysler. My inside diameter of the stock rubber boot measured 2" I.D. So I needed a 1-15/16 - 2" O.D. hose to cram into the boot. I brought the Mustang pump with me to NAPA so we could scrounge in the box of miscellaneous hoses. Luckily, it didn't take too long to find the hose I ended up using. The Mustang pump fit snuggily inside the hose and the hose fits very tightly inside the boot. After that I just needed to cut and splice the Mustang connector to the stock wires. Here are some pics below to show you what I used.
I have yet to build the engine that this pump will feed, but this is what I did. I probably should have gotten a 255lph pump; but whatever. I am also not sure if all pumps and boots are created equal. Hopefully this helps one or two of you out there.
