Wasn't sure if 5.0/5.8 Engine-Stock was the place for this so I came here.
Anyone here have some good experience with Holley carbs?
I've always had the problem of rough idle when the engine is cold, once it starts getting cold out, but this morning the car just would not idle at all, was getting flooded like crazy.
Tonight I've found out that the Boosters are leaking fuel into the carb at idle and low RPM.
Even when the engine is off, they are still dripping a bit, for 10-15 seconds.
What could be the cause of this, for it to just suddenly happen? I'm thinking maybe power valve somehow.
Other pages online, say float level is too high, but I've never adjusted the floats in the 3 years I've had the carb on the engine.
Pic related, you can even see fuel sitting on the throttle plate
