1987 Crown Vic 5.0
    1987 Crown Vic 5.0
    Anybody have a part number for a belt when you delete smog pump?
    I used a K060563 belt. Keeps the A/C while bypassing the smog pump. You may see the belt number in a few other number configurations, like 6K563, but the takeaway is it's a 6 rib belt that's 56-7/8" long.
    You’ll need to remove the pulley from the pump, though, otherwise the belt will contact the pulley. It’s only held on by three bolts and is not very hard to take off.
    My Cars:
      If you run the belt over the top of the idler/tensioner pulley, it won't touch.
        There is a sticky in this forum specifically covering this topic. Including an application you can tell the idiots at the parts counter. http://www.grandmarq.net/vb/showthre...nd-Smog-Delete
