which gasket sealant to use for throttle body and spacer?
    Good day and hope all of you are well,
    I'm going to swap throttle bodies this weekend.
    Which gasket sealant should I use for the throttle body and spacer?
    I do have new gaskets for the swap.
    I thank you always,
    Mike
    90 Colony Park LS with GT 40 heads and intake. HO cam, 65 MM TB, 67 MM EGR spacer. Has a 75 MM Pro Flow mass air sensor. Borla XS mufflers. 3L55. Shift kit, 2000 stall Tq convertor...Bilstein shocks, front and rear sway bars.
    90 Colony Park LS 64,000 miles all original. 3L55 tow package....front and rear sway bars.
    91 Grand Marquis GS....HO motor..Bilstein shocks poly bushings and police swaybars. This one handles the best.
    70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All original
    I haven't heard of anyone using gasket sealant...but if you want you can't go wrong with the Ultra Black.
    -Phil
      +1 dry on a clean and flat surface. If using any RTV, use just a smearing on the gasket surface.
      +1 Ultra gray or Ultra black are the ones to use.
        Thank you again Sly and Brown_muscle.
          None. Light use of a file to make sure the surfaces are flat and smooth should be all you need.
            Never heard of using sealant but I prefer the “right stuff” for these things.
            RTV usually has a cure time, the “right stuff” requires almost none.
            YMMV
              don't use rtv on those gaskets, just make sure all surfaces are flat and clean.
                Thank you Scott and Massacre.
                I will not use any sealant and will clean the surfaces will.
                Thank you
                  Carb base gaskets and throttle body gaskets, not O-rings, get a thin smearing of grease here. Never had one leak and no pealing either, the grease gets absorbed and swells it in time I guess. Old tip from way back!
                  No ... I'm not arguing with you ... I'm just explaining why I'm right ...
                  Now go ... and whatever you do ... have a safe trip!
                    Thank you Gadget.
                      Got the 65 mm throttle body and spacer on. I used no sealant.
                      I drove 10 miles and it was a blast.
                      I noticed the engine seemed to breath easier. Maybe the gas mileage will improve to.
                      Less effort on the gas pedal or so it seems.
                      The throttle body came with a new TPS and I also put a new IAC on. This all was so easy.
                      Today I'm going to check the voltage on the TPS at WOT and see if it is correct.
                      You know the saying .
                      If it ain't broke, don't fix it.
                      MAF 75 mm Pro M
                      65 mm Explorer TB, 65 mm spacer
                      68 mm mm GT 40 intake opening.
                      19 lb injectors.
                      Oh no! I've got the horsepower bug now.
                      Thank you
                        I wouldn't use any type of goo but they do sell gasket material at most part stores so you could cut your own gasket. I would use one of those.
