Welcome to the test copy of the new GMN. This is purely for testing. Nothing posted here will be saved, so please don't post anything important here. The data is from a copy of GMN from right around Thanksgiving 2022, so there are some gaps but there is enough here to work with. Please let us know what works and what don't so we can try and debug this before the final move.
Thanks!
90 Colony Park LS with GT 40 heads and intake. HO cam, 65 MM TB, 67 MM EGR spacer. Has a 75 MM Pro Flow mass air sensor. Borla XS mufflers. 3L55. Shift kit, 2000 stall Tq convertor...Bilstein shocks, front and rear sway bars.
90 Colony Park LS 64,000 miles all original. 3L55 tow package....front and rear sway bars.
91 Grand Marquis GS....HO motor..Bilstein shocks poly bushings and police swaybars. This one handles the best.
70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All original
Magnaflow they are. Drone terribly they do. Oddly phrased your title is. Annoyingly written my response must be.
Depends on what you want. I like the Dynomax Super Turbos because I like quiet exhaust systems nowadays. I'm running cats and 3" Dynomax 17792 mufflers on my 351W; but I haven't started that engine yet; so I have no critique of how they sound. I was running Dynomax 17749 muffs with the lopo; behind a full exhaust. They were very quiet.
I'm running Borla XS on my cars.
I don't like to draw attention with the sound at WOT. They do get a little louder when you open it up, but not enough to draw the police from a mile away.
They do well and have no horsepower loss. They actually have a slight gain in horsepower.
Almost always if not stock, some turbo mufflers.
Once bought a truck that had a FM 3SI/2.5DO, drone was bad at some speeds, a glasspack ahead of it helped.
No ... I'm not arguing with you ... I'm just explaining why I'm right ...
Now go ... and whatever you do ... have a safe trip!
I'm currently running some Flowmaster delta flows that I got for free on a custom bent 2" system with the two rear cats removed. It sounds good for what it is.
When I put on a new exhaust, it will consist of BBK headers, Pypes X-pipe with high-flow cats, and Walker QuietFlowSS 2.5" mufflers with Impala tailpipes. I have a good feeling about how that will sound.
—John
1985 Ford F-150 XLT Lariat
^^^^^^^^That will be quiet; basically the same setup I had with the lopo; except I had Summit turbos at first; then Dynomax 17749 muffs when they failed. It was quiet with the Summit turbos; so much that my Mom hated it; which is why I had to put cutouts on that exhaust.^^^^^^^^
I've mellowed out a lot and actually want a quieter car, but still with a bit of rumble. The new exhaust will also coincide with the new engine I'm having freshened up for it: 302 block, GT40 (non-P) heads, and a camshaft comparable to a '93-'95 Cobra. It'll essentially be a Cobra engine.
—John
Yes... yours done horribly. Mine don't drone at all. I was shocked how bad yours drone.
pretty sure its the Fox H pipe. Fox cars are really prone to drone issues if things are not exactly so. The black Mark VII droned pretty badly too. Whenever that thing needs exhaust work again, or whenever I feel motivated to drive it more, I'll have stock-style exhaust made up for it. Probably a little larger than factory but using the Panther routing and such. I strongly suspect that will make the problem go away.
