Baseline numbers, the third (and final) run was 123.5 hp and 239.3 tq. I'll be back with more power.
My first step toward 300+ HP....
LOL, OMG. These cars are so sad....I'm glad I never baselined my cars....
peak torque is so low, it's not on the graph...and peak HP at 3350...wow...
The motors make a lot of torque though. My 87 only had 275 with the work I did to it. The HP was 195.Builder/Owner of Badass Panther Wagons
The hp curve is awful flat tho, which is nice. Sucks how low it is tho lol.
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Originally posted by gadget73The hp curve is awful flat tho, which is nice. Sucks how low it is tho lol.1999 CVPI
Old Rides
1988 Ford Mustang GT (trickflow stage 1)
1989 Mercury Grand Marquis LS (5.SLO)
1989 Ford Thunderbird SC (3.8 Supacharged)
The 3G alternator, ASP underdrive pulley and an electric fan are going in this weekend. I'm not going to dyno it after these little changes because it will be a waste of money. I also have to do a leakdown test and decide if the 82,000 mile shortblock is healthy enough for the HO Convo.
'90 Mercury Grand Marquis GS
5.4L swap coming soon.
Shortblocks in these hold up very well. When I tore down the 120k mile motor in my Mark VII, it had visible factory crosshatch marks on the cylinder walls and zero ring land.
didnt your townie make 129 rwhp?
It made 129 rwhp on a Dynojet 248C. The GM made 123 rwhp on a Dynojet 224x. The 248C was an "in-the-floor" type dyno. The 224x had a "drive-on" type lift. (I don't know any other details other than the shop with the 248C charged $150 and the other shop only $75). The $75 shop is also in the next town over (5-10 minutes away).
That's awesome, dude! I wanted to put mine on a dyno, but VERY shortly after I started getting where I'd have the balls to go (even on a blown transmission), the oil pump went on vacation. So... no baseline. I'm gonna use your numbers as baseline, though, since it's basically the same set-up I was running (close enough to not matter, at least).
Let us know if you can feel the difference with the electric fan.2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
I have all the HO Conversion parts. I just have to save up for the labor cost. The weather isn't the best up here in the Northeast and I would be doing everything in the driveway. (My neighbors would call the police and I say I'm running a "chop shop" or something, they're very inquisitive). The shop would probably have everything bolted on in less than a day.
Seeing as how it takes 265hp at the rear wheels to get a 4000 lb car to go 14.60s, and seeing as mine weighs 4180# and has gone 14.10, I think I passed the 300hp mark.
Still looking for that evasive 13 sec. time slip.Speed cost....how fast u wanna go??
It's not how much hp u have...
It's how much hp u can put to the track...
Let's seperate the men from the boys and put that power to the track using street tires and stock suspension components
'Tis infinately better to sit quietly and be thought a fool,
than to speak and remove all doubt.
I refuse to have a battle of wits with an unarmed person.
Originally posted by SLYDAWGSeeing as how it takes 265hp at the rear wheels to get a 4000 lb car to go 14.60s, and seeing as mine weighs 4180# and has gone 14.10, I think I passed the 300hp mark.
Me likey1983 Grand Marquis 2Dr Sedan "Mercules"
