I know it leaks oil. Dont care. This is all mustang stuff btw. Bolt on, no mods.
Pics of my exhaust.
Pics of my exhaust.
1989 Grand Marquis LS
flat black, 650 double pumper, random cam, hei, stealth intake, Police front springs, Wagon rear, Police rear bar, wagon front ,exploder wheels, 205/60-15 fronts 275/60-15 rears, 1 5/8" headers, 2.5" offroad x pipe, Eclipse front bucket seats, Custom floor shifter, 4.10 gears, aluminum driveshaft and daily driven. 16.77@83mphTags: None
Archangel
Seems like you flattened the passenger side pipe near the bent before the main cat, would you be able to lift your exhaust couple of inches to avoid stuff like that? You seem to have plenty of clearance under the tranny crossmember, so look into that.
If the exhaust is flattened its from hitting the ground while underneath my capri. I have not modified any part of it.1989 Grand Marquis LS
Mileage is about the same. No cats so there isnt enough heat to make the ego sensors work properly so it runs a little rich. But way more power.1989 Grand Marquis LS
I sit high enough it doesnt really matter man. I may have lost an inch or 2 but it sat the same way under my capri.1989 Grand Marquis LS
You didn't extend the midpipes did you? If you extend them enough to put the mufflers back in the factory position you can get the ground clearance back.
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Didnt extend. I can extend em but maybe 6 inches at the most. I wont do that until I get tailpipes on this beast.1989 Grand Marquis LS
